Visualization
Rendering styles...
Llian
I remember seeing a setting for the rendering.This is a pencil sketch and I want something else. Where is the setting? I know it is somewhere in there.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
David Maudlin
Lilian:
Open the PhotoRendering Settings palette, change the Engine setting.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David Maudlin
Lilian:
David
Llian
Thank you David.
I have found the photo rendering setting…all is good now.
Cheers
David Maudlin
Lilian:
Great, thanks for posting back.
David
