Peter wrote:
code for a light source type object in the GDL
GS does not have a truly diffuse light source
so apparently we are stuck with some form of cone shape.
Peter Devlin
Partly true, partly not.
My book spends a lot of time demonstrating making and controlling diffuse light using the light cone light source. Exercises in the book indicate precisely how to illuminate an entire room with soft light coming from only one light source. This information remains current from Archicad 9 to Archicad 10.
The "light cone down" is the energy source used by most of the "lamps" along with the magical "wall light diffuse."
In doing the travelling seminars, I've been expanding this part of the lecture to make upp for simplifications in sunlighting techniques available in Archicad 10. The seminar is coming to the Bay area, Los Angeles and Orange County at the end of January.
Buying the book will immediately give you the power to cammand this light, or you could experiment for a week on your own like I did.
The attached image is one of the light cone development exercises I did in discovering how to control soft llighting.
Dwight Atkinson
