Achille Pavlidis
Scale texture with Cinerender engine
Is it possible to scale textures when rendering with the new Cinerender engine, as it is possible to do with the Internal engine?
Mac OS 26.1 | AC 29.1.0 INT 4006 FULL
2 Replies 2
Not sure what you mean. Do you mean to set the physical horizontal/vertical size of the texture? If so, then yes... I can post a screenshot if you're not seeing the setting.
Achille Pavlidis
OK, I found it
Thanks Karl
