Not sure what you mean. Do you mean to set the physical horizontal/vertical size of the texture? If so, then yes... I can post a screenshot if you're not seeing the setting.
One of the forum moderators
AC 28 USA and earlier • macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
