2008-03-11
08:37 PM
2023-05-11
01:42 PM
Noemi Balogh
2008-03-12 01:57 PM
2008-03-12 04:57 PM
2008-03-12 05:14 PM
Dwight wrote:My screen is only 23"; would like to work on a widow of about 8.5x11 with 300 resolution so when exported the pixels are there and do not have to be interpolated by the other program.
And that kills the charging lion.
.... when you print, the printer automatically resizes the image to the physical page size.
2008-03-12 05:29 PM
2008-03-12 05:31 PM
2008-03-12 05:40 PM
Dwight wrote:Okey Oky just one MRS. spelling and see what I get
I know what you mean. I heard that widows ARE the best, driven as they are by grief. And you think that is work? I should have your job.
Isn't this issue more about how Piranesi deals with an image? I do not believe the 3D Archicad window can be re-scaled.
2008-03-12 05:47 PM
2008-03-14 04:40 PM
Joseph wrote:As the Piranesi export is a rendering, you just specify the pixel size.
As I understand the default resolution of the 3D window (OpenGL & Internal Engine) is set to 72 dpi. Can one set Resolution in 3D window to 300 dpi to achieve 8.5"x11" window area. I am trying to export the image to Piranesi to achieve sketch/water color rendering.
Thanks,
Joseph
2008-03-14 05:03 PM
Djordje wrote:Do I need to only set the Size in Photorendering Settings of LightWorks and then Save As from 3D window
