Thursday - last edited Thursday
After getting tired of the numerous commercial AI rendering services out there, I decided to create my own.
The goal is simplicity. The add-on captures a snapshot of your current 3D view when you click "Capture Current 3D". Simply enter your prompt below the captured image and click Send. Not satisfied with the result or want to make some adjustments? Just enter another prompt, and the AI will continue working on the last generated image.
The add-on is quite flexible and supports multiple AI engines, including Google's Nano Banana (Gemini), BFL Flux, or even your own locally hosted models through Forge (e.g., Stable Diffusion, Flux, and others).
The easiest way to get started is to create an account in Google AI Studio (https://aistudio.google.com/), generate an API key, purchase some credits, paste the API key into the settings dialog, and you're ready to render.
Best of all, the Addon is completely free and open source. The source code is available on GitHub: https://github.com/malamalca/BIMrender
Contributors are welcome!
Pre-built add-on releases can be found in the Releases subfolder (download the add-on from there).
Enjoy, and please send your feedback.
Friday - last edited Friday
The animation below is made with locally installed AI model Flux-2 (running on RTX 5070Ti).
It is not as good as commercial AI models but for quick renders, it does its job.
yesterday
Hi Miha,
Very interesting tip. Please can you explain how I can run this plugin in archicad. Apologies, I'm not great with Github etc.
yesterday
Doing this API enabling in Gemini NOT FOR THIS ADDON I was charged 150 euros.Obviously I should had read
more about the terms.I did it to try another addon.This GEMINI intergration obviously is reaaly promising
As long as this Archicad 's AI Visualizer is not moving forward Gemini will prevail.
