2007-09-21
07:39 AM
2023-05-11
12:24 PM
Noemi Balogh
2007-11-06 01:20 PM
2007-11-06 05:17 PM
2007-11-06 06:25 PM
2007-11-06 06:28 PM
2009-06-02 02:49 AM
tigr wrote:I cant get this to work for me.. when I do a light works render save it and then set it as my background image IN the photo render settings box. Set all my sketch settings up then hit render. when the sketch render is done it just shows my background image that I got from LW.. if I remove the image and hit render I get the usual black and white sketch done… how do I get it to use the LW image as the background and put the sketch lines over it??
Thanks Mats.
Sketch + LW was described in many posts (thanks Tom) and the technique is a bit different every time, but basicly this is what you do:
1. Render a scene with LW (don't put to much work in it, doesn't have to be perfect. Sometimes I even use 3d screen shots instead !!)
2. Save it.
3. Now you can use it as a background for your sketch render or read further.
4. Sketch render settings (not optimal, just mine):
- Koh-I-Noor
- paper roughness 10%
- antialiasing - max
- line thickness - 16%
- no lines overstreching
- shadows, hatch and lines distortion...you need to decide
5. If you want to put some extra touches in the scene you want to compose it in Photoshop or Gimp.
- make the sketch a layer, put on top of LW render
- use "Multiply" or "Overlay" as a layer blending option
- mess with the LW render to get what you need
- flaten and save
Have fun.
2009-06-02 02:58 AM
2015-02-19 12:32 AM
2015-02-20 03:51 PM
2016-06-13 03:34 PM
2016-06-13 03:36 PM
