Dwight
Solution to slow rendering
Dwight Atkinson
5 Replies 5
Steve Jepson
thanks for posting that link. I hope Graphisoft is already working on software to work with 64 bit processors.
Dwight
You think so?
Dwight Atkinson
JCovarrubias
Graphisoft Alumni
Graphisoft Alumni
Has software like "Mental Ray" been mentioned on this forum as a possible solution for handling large renderings in ArchiCAD? Maybe not this software in particular, but the aspect of "network (through distributed processing) renderings" for example...
http://www.mentalimages.com/2_1_0_mentalray/
"mental ray® generates images of outstanding quality and unsurpassed realism and achieves scalable performance through the exploitation of parallelism on both multiprocessor machines and across networks of machines. The software uses advanced and proprietary acceleration and recursive sampling techniques for faster rendering on even the smallest, single processor machines."
http://tr.graphisoftus.com/
Jeffry Covarrubias
GS US Technical Support Team Leader
P-C2D 1.86GHz/2GB w/ 256MB GeForce 8600GTS; G4 OS 10.4.10 1GHz/1GB "[that other software] is a fancy set of electronic marker pens"
Dwight
there are several applications that use network and distributed processing.
Google "render farms" to see: Render King our fave with Cinema 4D and others serviced.
Dwight Atkinson
I have hopes that Apples' X grid will eventually help with rendering times. Has anyone looked into using it with AC?
Here is a link to X grid.
http://www.apple.com/server/macosx/features/xgrid.html
