Visualization
Spotlamp wall and LightWorks
Can someone explain to me why the spotlamp wall 12 give this square result in lightworks? Dear Dwight? Many thanks for an other time!
11 REPLIES 11
Dwight
Perhaps you could post a diagram of the light configuration in this model.
Dwight Atkinson
Dwight
Also, the actual size of that room and the settings for the lamp itself.
Dwight Atkinson
As soon as possible, because at this moment i have not the file. For the story with internal engine and the same configuration everythink it's OK. The trace is circle.
Dwight
Just to speculate:
the spotlight is obsolete.
If you bought my book, you'd know this. On sale now.
Use the lightcone instead....
Dwight Atkinson
The dimensions of the room....
and spot parameters. Thanks Dwight!
Dwight
CAN'T READ IT.
Dwight Atkinson
I am sorry!
Dwight
increase 'r' value to at least .100
Dwight Atkinson
