Visualization
Stipple vectoral fill not rendering in perspectives?
rob2218
See attached.
Basically, when I switch out the vectoral fill pattern in a surface material I created, the "stipple" in a sketch rendering wont render in.
I constantly have to keep switching out the a "Diagonal 1" line" fill pattern to make the center area of the design appear to be a darker "grey" painted color.
I'm rendering in "sketch mode" type technique.
The stipples fill (no matter how dense I try to make it) just wont render.
What could be happening here?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Maybe those points or strokes in the stipple fill pattern are just too small for the Sketch Rendering Engine to consider them large enough to display.
rob2218
hum....good point (no pun intended).
Ok, so what I'll do then is create my own fill which has short lines instead of points....more like "scratches" on the wall.
I'll put the short (perhaps 1" long lines) very close together to see if the pattern shows up on the rendering sketch.
Thanks Lasz.
i>u
Edgewater, FL!
SOFTWARE VERSION:
