Visualization
Strange shadow casting
Does anyone know what causes this strange shadow (see image)
14 REPLIES 14
Is the roof made with the mesh tool? Perhaps there is an a problem with it that is preventing it from modeling properly (like a self-crossing edge). Check to see if it is solid in section.
No the roof is done with the roof tool; there is some slab (for soffit and fascia) that overlaps with the roof, could overlapping cause this maybe?
It could be the overlapping. Elements that overlap cancel each other (creating apparent voids) in 3D so it would make sense. I'm always pretty fussy about having no overlaps so I haven't run into it myself.
Erika Epstein
By any chance do you have some lights turned on ?
Aurora Borealis?
One for the Dwightster where ever he is.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Djordje
Glass reflection, methinks.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Different project, same problem. I’m using AC 10 default template settings for the materials, can’t always reproduce the problem so not sure when it happens. Anyone else encounter something like this
(please no comments about the design!! hopefully we'll find a way to convince them to change things)
Thomas Holm
A way tomake it more interesting could be to go the other way and create a roof that matches the shadow
Dwight
Of the light sources in the scene, are any of the shadow resolutions= 0.
You see boxy shadows when shadow resolution is lower than rendered pixel resolution.
Dwight Atkinson
I'm not using any extra light source, just built in Sun ( at 100 in the photorendering settings & Ambient @ 100)
