‎2023-09-28 02:15 PM
In this post: https://community.graphisoft.com/t5/Getting-started/Archicad-27/ta-p/378760
it is stated:
"Create real-time visualizations more comfortably with the revamped Archicad - Enscape connection
even on the macOS platform."
Where is it? When will it be finally available?
Thank.
Kind Regards
Roman
Solved! Go to Solution.
‎2023-10-02 07:05 AM
@Romans I was wondering this too, so I went digging.
Found this article on the Enscape website.
When I downloaded the free trial, it' gave me the MacOS plug-in files for Archicad 25 - 27.
‎2023-10-02 07:21 AM
@UsernameNotFound: Thank you!
This is then brand new information.
Unfortunately, Macs based on Intel chips (CPU) are off the table (see system requirements).
I guess the majority of Archicad users on Macs are still using machines with this Intel-based hardware...
The Pro-lines have good discreet GPUs, but Chaos did obviously decide the render these useless if you consider to opt for Enscape real-time viz.
‎2023-10-11 09:48 AM
It's running on my M2!!
Amazing!
‎2023-10-11 10:41 AM
Nice for you.
How many Mac users do you think are lucky enough to work on ARM hardware already?
Why should I recycle my very good Intel Macs?
‎2023-10-12 06:10 AM
Hi Romans, I totally agree with you!
I have an IPad 2 that is perfectly running and still holding batteries…but there is no OS update available to install current apps….
But that is rather an Apple issue than the problem of a software provider.
