Visualization
Streamlined Archicad - Enscape Connection on Mac - Where is it?
Romans
In this post: https://community.graphisoft.com/t5/Getting-started/Archicad-27/ta-p/378760
it is stated:
"Create real-time visualizations more comfortably with the revamped Archicad - Enscape connection
even on the macOS platform."
Where is it? When will it be finally available?
Thank.
Kind Regards
Roman
Apple iMac Pro with macOS Sonoma, AC 5.0 to 27 INT and GER, all the latest
UsernameNotFound
@Romans I was wondering this too, so I went digging.
Found this article on the Enscape website.
When I downloaded the free trial, it' gave me the MacOS plug-in files for Archicad 25 - 27.
5 REPLIES 5
UsernameNotFound
@UsernameNotFound: Thank you!
This is then brand new information.
Unfortunately, Macs based on Intel chips (CPU) are off the table (see system requirements).
I guess the majority of Archicad users on Macs are still using machines with this Intel-based hardware...
The Pro-lines have good discreet GPUs, but Chaos did obviously decide the render these useless if you consider to opt for Enscape real-time viz.
It's running on my M2!!
Amazing!
Mac OSX - up to date
GER Archicad Full, Up to date
Nice for you.
How many Mac users do you think are lucky enough to work on ARM hardware already?
Why should I recycle my very good Intel Macs?
Hi Romans, I totally agree with you!
I have an IPad 2 that is perfectly running and still holding batteries…but there is no OS update available to install current apps….
But that is rather an Apple issue than the problem of a software provider.
