Sun setting - is archicad accurate?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2011-11-13
06:47 PM
2023-05-11
02:08 PM
Noemi Balogh
For 21st September 9.00am Archicad gives
Azimuth 119.33
Altitude 31.19
The online calculator gives
Azimuth 60.39.20
Altitiude 30.59.06
I assume arcihicad uses true north not magnetic north?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-11-13 07:10 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-11-14 05:30 AM
I have done some sun/shadow studies for projects in Australia and one problem I ran into is getting the correct survey data. Magnetic north has shifted quite a lot since some surveys were made.
You may be stopped from getting a permit unless you can prove the shadows from your house will not put too much shade on the neighbors pool.
You will find quite a lot of difference even in official records that tell what direction magnetic north is from the same spot.
Also, magnetic north pole has been shifting towards Russia at 40 miles a year for the past decade or so.
You may need to calibrate north in ArchiCAD to match some actual compass readings and verifiable shadow lengths.
http://www.airport-data.com/world-airports/YMAY-ABX/
Even then you will probalby need to base the shadow lenghts on an agreed to set of data rather than actual observations. Good luck
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-11-14 06:51 AM
As far as the sun position in BIMx is concerned it does generally appear the about right but I guess GSHQ need to pronounce on this
you can't build a line
Mac Studio
iPad Pro
iPhone
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-11-14 05:59 PM
ArborCAD ? http://www.chrisskellern.co.uk/software/download.htm
Shadowspro ? http://www.shadowspro.com/en/download.html
