‎2015-10-2303:34 AM - last edited on ‎2023-05-2602:57 PM by Rubia Torres
‎2015-10-2303:34 AM
I was trying to use the surface painter in archicad 19, however, it says surface painter is not supported in legacy mode. I am not aware of any sort of legacy mode, and I have created my model through archicad 19 as well. I tried save as it again, but still the same. donno what the issue is, hopefully someone can help me out!
Thanks!
Make sure 'Use legacy intersection and surface methods for model elements' is turned off.
Then you can use the surface painter.
It will also mean you will be using the Building Materials for Priority Based Connections in 3D and sections.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
