Texture map rendering dark
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2005-01-11
02:32 PM
‎2023-05-11
12:39 PM
Noemi Balogh
I've attached a rendering done in ArchiCAD of the building looking all gloomy and I've posted the same texture rendered in Strata CX plus the original texture map (which maybe of use to others btw)
TIA
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-11 02:33 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-11 02:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-11 02:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-11 05:32 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-19 07:20 PM
I also took a closer look at the Lightworks sun settings by deactivating the Essential only button.
In there as well is a setting for
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-19 07:52 PM
Noon daylite in Upper Hutt New Zealand where the whitest light in the world is found should be 5000 degrees Kelvin.
Light bulbs range from 1900 [orange] upward.
You'll discover that adjusting both the ArchiCAD Sun color and LightWorks Color Temperature makes a hybrid color. Keep ArchiCAD color white if using LightWorks.
Now you see why the book is taking so long. Like peeling an onion, this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-21 09:40 AM
The daylight has many temperatures, the neon lights have another, incandescent bulbs the third ... that is why you have different color temperature 35mm and other films to use. If you use daylight film, sensitized to blueish daylight, the neon-lit scenes will be green, and the bulb-lit scenes will be more or less yellow.
So it is not unimportant ... to know
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-21 11:52 AM
wr1nkles wrote:
i did some research on this "colour temperature", if your interested, check out this website at "http://members.shaw.ca/jimht03/light.html"
cheers,,
I couldn't get your url to work. So I had a look for some info myself and came up with this.
It has a simple table listing in Kelvin various lighting scenarios and what the colour temperature would be for each.
Thing I'm not sure about is what units is the Lightworks Colour Temp setting using is it Kelvin? The slider gives a range of 0 to 50,000 bushels, banana skins who knows?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2005-01-24 06:30 PM
fuzzytnth3 wrote:Coconut peels stacked into oysters, methinks ...
It is Kelvin
HP Omen
