‎2010-05-23
02:32 PM
‎2023-05-11
03:53 PM
Noemi Balogh
‎2010-05-23 08:37 PM
‎2010-05-23 09:04 PM
Erika wrote:The lines on the screen appear crips, however when I go to print the plan etc. there do not appear as crips as AutoCAD lines...
Nathan,
Let's first see if we can help you print crisply direct from archicad.
Can you post 2 samples one of anon-crisparchicad drawing and the other of a crispautocad one so we can see what you see?
‎2010-05-23 11:09 PM
NStocks wrote:It could be a PDF issue. I thought this was fixed a while ago but once upon a time Postscript printers (the underlying predecessor of PDF) would make technical drawings look like c**p. It had to do with the different priorities of graphic design vs technical drawing. This should be solved with high resolution in the PDF. Maybe you need to bump up the dpi of your output.Erika wrote:The lines on the screen appear crips, however when I go to print the plan etc. there do not appear as crips as AutoCAD lines...
Nathan,
I heard this a few weeks ago on this forum too and wondered what the solution would be...
EDIT: I don't print directly from ArchiCAD. I have to save as a PDF then crop the page to remove the ArchiCAD Educational License logo, otherwise the tutors tell me off and take points off
‎2010-05-24 12:41 AM
Matthew wrote:I see.NStocks wrote:It could be a PDF issue. I thought this was fixed a while ago but once upon a time Postscript printers (the underlying predecessor of PDF) would make technical drawings look like c**p. It had to do with the different priorities of graphic design vs technical drawing. This should be solved with high resolution in the PDF. Maybe you need to bump up the dpi of your output.Erika wrote:The lines on the screen appear crips, however when I go to print the plan etc. there do not appear as crips as AutoCAD lines...
Nathan,
‎2010-05-24 04:17 AM
‎2010-05-24 07:11 AM
‎2010-05-24 02:09 PM
Dwight wrote:Because I have my own A3 printer, and 70% of my work is on A3 sheets, therefor I can't cut those down. If I print on A2,A1 or A0 I can quite easily cut those down, but it's A3 that I need the most.
You seem to be going to a lot of trouble to cut off a licensing logo.
Why not just cut the paper down after printing?
‎2010-05-24 05:54 PM
‎2010-05-24 06:20 PM
Dwight wrote:
Time to invent a new format.
