2010-05-23 02:32 PM - last edited on 2023-05-11 03:53 PM by Noemi Balogh
2010-05-24 06:36 PM
NStocks wrote:Does it take a roll feed? Would that help? (I've never seen the watermark.)Dwight wrote:Because I have my own A3 printer, and 70% of my work is on A3 sheets, therefor I can't cut those down. If I print on A2,A1 or A0 I can quite easily cut those down, but it's A3 that I need the most.
You seem to be going to a lot of trouble to cut off a licensing logo.
Why not just cut the paper down after printing?
2010-05-24 07:07 PM
Matthew wrote:Yes, it does take a roll feed but this will mean that more time is ' wasted ', cutting each page especially when I work very closley to the deadline aka printing 1 day before due date !NStocks wrote:Does it take a roll feed? Would that help? (I've never seen the watermark.)Dwight wrote:Because I have my own A3 printer, and 70% of my work is on A3 sheets, therefor I can't cut those down. If I print on A2,A1 or A0 I can quite easily cut those down, but it's A3 that I need the most.
I still can't understand a prof dinging a student for using an educational version of the software.
2010-05-24 07:13 PM
2010-05-24 07:37 PM
Dwight wrote:We get told off for ' Sticking and Gluing ' ....
Like, print out your title block separately and glue it over top of the logo, then.
2010-05-24 07:45 PM
2010-05-24 07:47 PM
2010-05-24 08:00 PM
Dwight wrote:...and reuse the matting for the next one (cost presumably being an issue)
Seriously, now, how about matting? One of the most effective presentations I saw at school was hand sketches in pencil on plain newsprint with dark, irregular mat board surrounding it. You could COVER the logo without pasting....
2010-05-24 08:09 PM
2010-05-24 10:37 PM
NStocks wrote:In theory, a PDF should be at least as good as a plot file. After all, it's a richer file format. It all comes down to the printing process and the quality of the rendering software.
Does a PDF loose that much quality as apposed to printing directly from ArhiCAD ? ( I will test this later )
2010-05-24 11:03 PM
