Visualization
Transparancy in Isometry
Why is the transparancy impossible in isometry?
As you see the surface of glass is opak...
5 REPLIES 5
Rob
the problem is somewhere else mate,
if you are in OpenGL mode it has some limitation with transparency, the transparency virtually does not work it is defined on true/false basis so if there is anything considered as transparent the transparency will be always 100% and vice versa. Settings to setup the 'treshold' for this see snapshot 1.
if you are in the Internal Engine mode set the transparency in shading on, see snapshot 2.
::rk
I have checked already.
But the perspective (not isometry) shows the right transparancy.
Just isometry makes problem...
I have updated the graphic driver, maybe it is because of that?
New installation of driver doesnt help.
This is a bug in LightWorks when you select the Best Antialiasing. Choose another Antialiasing level or after Hotfix 1, use the newly introduced Best Antialiasing which solves rendering thin bars as well.
Thanks Chrispy.
That was.
