Transparent lampshade
I am trying to render a kitchen that has a few pendant lights over the island but every time I do the lampshade, that is supposed to be frosted glass and translucent is coming out metallic and opaque. I have gone through the settings a couple of times and make adjustments to things that I think should change it but I am not getting the wanted result. I have attached a copy of the render output and an example of the pendant lights I am trying to emulate.
Carstenem
this is just a hunch but your lamps might still have the "overwrite" material on, which needs to be off for the other surfaces to work, see markup.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Earthworm
Check your Cinerender General Options: https://helpcenter.graphisoft.com/user-guide/77526/#CSH_1578
Maybe your raydepth is too low or transparency is turned off.
ArchiCAD 27 | Intel Xeon W-2225 - 4.10GHz | 32 GB RAM | GeForce RTX 3080 | Windows 10
