stefan
Tutorial ArchiCAD to Cinema4D
This is my official attemption to get a tip-of-the-month reward 😉
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/tips/ac2c4d.htm
I've allready made a few improvements based on the kind review of Karl Ottenstein. Other suggestions are welcomed.
(There are a few minor corrections, which will be visible on 3/11/2003 - our webserver updates overnight)[/img]
Archicad-user since 1998
my Archicad Book
15 Replies 15
Djordje
Stefan,
As this is important for many users, please check whether the link in the Tips&Tricks forum is OK; please update me by private message if anything is to be added/removed/updated.
Thanks,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thomas Holm
Just one question: Is that ugly thing a REAL project???
Thomas
(no offense intended)
Djordje
One of the example files.
Djordje
HP Omen
stefan
Thomas
It is included in ArchiCAD 8.0/8.1 and I give a reference to it on the tutorial site. It's not mine, but it is accessible for every ArchiCAD 8 user and is a bit bigger then the projects I use to do, so might reflect real office situation better.
Come on, it's not so bad.
You wouldn't want to see a Skyscraper or dull office building tutorial, do you?
my Archicad Book
pls help
I moved from artlantis to c4d and as a beginer i have this problem
Is it possibe in c4d to reaply materials and assign new one by planes, objescs etc. something like artlantis ?)
i export from ac to 3ds and then to c4d
i have c4d 7xl
stefan
NeckoFromSarajevo wrote:
pls help
i have c4d 7xl
Can you rephrase your question?
You mean billboards: in Cinema4D they can be made by creating a plane, making a material using alpha-mapped pictures.
my Archicad Book
stefan
Addition: I also applied the same picture into the Color channel and disabled the Specular channel.
You might assign it into the Luminance channel to prevent the material being influenced by lighting if you want.
my Archicad Book
Ok, i will try to explain in tihs way
I created a wall i ac and that wall is wood from all sides. Then i export it to 3ds and open it in c4d. That wall is recognize as wood and thats ok. Now i want to set inner side of wall to be brick, outher side to be green. How will i do that.
In artlantis that task will be accomplish very easy, i will go to "windows" then to "reapply materials" and there i have options:planes, paralel planes, object, materials
Try to set up materials in AC for "inwall" & "outwall" - keep the material name 8 characters or less. Apply them to the walls in AC as inside material and outside material. Export using materials as option and see if you can see them separately in C4D.
