ā2003-11-03
05:23 PM
ā2023-05-11
02:22 PM
Noemi Balogh
ā2003-11-03 05:39 PM
stefan wrote:As this is important for many users, please check whether the link in the Tips&Tricks forum is OK; please update me by private message if anything is to be added/removed/updated.
This is my official attemption to get a tip-of-the-month rewardš
http://www2.asro.kuleuven.ac.be/asro/English/HOME/SBs/tutorial/tips/ac2c4d.htm
I've allready made a few improvements based on the kind review of Karl Ottenstein. Other suggestions are welcomed.
ā2003-11-05 12:13 AM
ā2003-11-05 08:39 PM
Thomas wrote:One of the example files.
Just one question: Is that ugly thing a REAL project???
ā2003-11-06 09:32 AM
Thomas wrote:It is included in ArchiCAD 8.0/8.1 and I give a reference to it on the tutorial site. It's not mine, but it is accessible for every ArchiCAD 8 user and is a bit bigger then the projects I use to do, so might reflect real office situation better.
š
Thomas
(no offense intended)
ā2003-11-12 01:06 AM
ā2003-11-12 09:32 AM
NeckoFromSarajevo wrote:Can you rephrase your question?
pls help
I moved from artlantis to c4d and as a beginer i have this problem
Is it possibe in c4d to reaply materials and assign new one by planes, objescs etc. something like artlantis ?)
i export from ac to 3ds and then to c4d
i have c4d 7xl
ā2003-11-12 09:36 AM
ā2003-11-12 02:52 PM
ā2003-11-12 06:13 PM
NeckoFromSarajevo wrote:Try to set up materials in AC for "inwall" & "outwall" - keep the material name 8 characters or less. Apply them to the walls in AC as inside material and outside material. Export using materials as option and see if you can see them separately in C4D.
Ok, i will try to explain in tihs way
I created a wall i ac and that wall is wood from all sides. Then i export it to 3ds and open it in c4d. That wall is recognize as wood and thats ok. Now i want to set inner side of wall to be brick, outher side to be green. How will i do that.
