Visualization
Twinmotion direct import with design options
sknsnw9
What do you guys do when you have several options with the direct import?  Without having to save as the file for each option then add the import file in twinmotion.  That seems cumbersome. I should be able to import 3 options from one file.  Is there a way to do this that I might have overlooked? Or is there an easier method?
Archicad Solo 24 - 28 : Windows 10 Pro 64-bit : 16 GB ram / Intel Core i7-4770k @ 3.50GHz : NVIDIA GeForce RTX 3060 / MacBook Pro M3 Max
jeff_yote_studio
Curious about this too.... I found a Revit tutorial that essentially suggests the same - i.e., each option is a different FBX file while one can remain Direct Link. I am not sure Twinmotion has the support for options feature in Archicad or Revit.
Archicad 27
derekjackson
That's the process we use - pull the consistent elements (such as the site) in as one main import, then import the various options separately. You can then use Twinmotion's View Sets to organise and visualise them. Takes time on initial export / import, but is then very quick to work with once they're in.
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
