Visualization
Twinmotion for Archicad 24
Scott Bulmer
Is Twinmotion Direct available for Archicad 24 and if so where is it? Thanks, Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
The TwinMotion direct link for AC 24 is available from Epic today:
https://www.unrealengine.com/en-US/twinmotion/plugins
EDIT: OK, so it says it installed, but in 24, it says to go back to the site to update the plug-in... Plugin in the 24 Add-Ons folder is dated July 8 after running this new installer. To be sure, I deleted that add-on and ran the plug-in update again... but got the same add-on (July 8 date) and the same warning on launching 24 that a new version of the 2020 direct link is available. Repeat forever... So, Epic either didn't really get this tested/working, or the error message is wrong...
It may be that the 2020.2 version of TwinMotion is required for the plug-in to work... that version is showing in the Epic Games Launcher. I have 2020.1.2 installed ... and it is so dumb that the TwinMotion app itself cannot notify us of updates. 😞 Will try that.
In spite of the error message, the model IS sent to 2020.1.2...
One of the forum moderators
AC 28 USA and earlier   •   macOS Sequoia 15.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
17 REPLIES 17
I don't yet see it listed. You should check its availability on this web page:
Sam Wheatley
Here is the response I received, just a few days ago:
I just got some more information from our person who is in contact with Epic Games. They let me know that we are waiting for Epic to update their plugin to include the latest version of Archicad. Sounds like we are expecting it in the next couple of weeks.
Hope this helps.
ArchiCad 26 US
IMac Pro
iMac 3.2 GHz Intel Core i5 16 GB
NIVIDIA GeForce GT 755M 1024 MB
It's not available yet. However, I would recommend not waiting for it and just proceed by saving out an FBX file from ArchiCAD (use the "Save As" Twinmotion) option from the 3D window. The previous direct links were very buggy at best and caused a lot of crashes.
Process:
1) Save out FBX file from ArchiCAD
2) Open new file in Twinmotion
3) Go to Import tab and bring in the FBX file
4) Save file as .tm file
5) Go back to ArchiCAD and make edits as usual
6) Resave FBX file replacing older version (of course use the same name)
7) In Twinmotion go to the import tab and select the FBX file that was originally imported and refresh
8 ) New ArchiCAD model will appear where old one was keeping all of the Twinmotion texture edits from before
9) This is basically a manual process of direct link, but without the crashes.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 27 (user since 3.4, 1991)
16" MacBook Pro; M1 Max (2021), 32GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Scott Bulmer
That process works great, thank you so much Rex~! Regarding Direct Link, I too was experiencing quite a bit of bugginess but thought it was my system, thanks also for confirming that issue. Scott
Minh Nguyen
Graphisoft Alumni
Graphisoft Alumni
Hi All,
Thank you for your questions!
Although I do not have any official information from Epic Games about when Direct Link addon will be available for Archicad 24, I hope it will happen in the coming weeks!
Regarding the issue with Direct Link's unreliability, sadly, this is not the first time I came across this issue. Although I never had it, I believe this is system-specific. Unfortunately, the addon is developed entirely by Epic Games, therefore we cannot tell exactly what caused those crashes and errors. I hope with time, they will be able to develop a much more stable version of it!
If you have any issue with Direct Link, I would highly recommend reaching out to Twinmotion's support, that can be found here: https://twinmotionhelp.epicgames.com/s/?language=en_US.
Let me know if you have any further concerns!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
So, after 7 hours to download over my slow internet (why does Epic make even UPDATES be 18 GB in size - have they never heard of patches? grr) - Having 2020.2 has no effect on the message displayed by the 'new' AC 24 plugin - it tells me to go update on every launch, from the page where I just downloaded the plugin. These guys. 😞
Carstenem
Thanks for the heads up saves me testing it out !
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
To clarify: it does seem to work for both 2020.1 and 2020.2 ... the issue is it displays a warning to update the plug-in every time AC is launched. Hopefully the update check error is the only bug / issue - so please DO test as you have some real models that could stress test it. 🙂
