Unwanted infill wall lines on 3D
Hi there!
How to get rid of infill wall lines on 3D? I'd like to present seamless wall.
Thank you.
2 Replies 2
To make these lines disappear, the walls concerned must all be perfectly coplanar and of the same material. If it is not possible then you must add a additional wall over all or add a graphic modification by an graphic override or a simple white hatch (last resort)...
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Thanks for the response. I will try to play with it and see how it turns out.
