Dwight
View Cone
Depends.
A good photographic compostion tells a story of the space, usually by placing something in the foreground. In this case, a wide angle lens is appropriate - over 60 degrees. After 75 degrees, strange foreshortening occurs and room size is unfairly exagerrated - good for 40 sqm condos......
While the lens chart attached refers to 35mm proportions and measures the DIAGONAL angle - not like ArchiCAD that measures the horizontal angle - it is close enough to start.
I do not believe there's a common angle since it is driven by the composition.
A trick is to invisibleize walls and shoot through them as if your project was a studio - leads to more telephoto shots that resemble catalog photos.
Dwight Atkinson
3 Replies 3
Dwight
There's this joke that is relevant to the discussion.
Man goes to his doctor "My foot hurts when I turn it sideways."
Doctor says " So stop doing it."
Dwight Atkinson
Dwight
try inner 60 outer 120 with angle falloff 2
Dwight Atkinson
Dwight
do this with one light aimed down to light a wall.
what is it supposed to look like?
play with it until it looks right.
too many fixtures ruins the exercise.
Dwight Atkinson
