Views not linked to cameras in ArchiCAD 20
In previous versions, I could create a view from a camera and, when I moved the camera, the view would also change positions. This no longer seems to be the case in 20. Now, the created views no longer seemed to be linked to the camera views. Is there a new setting or something I am missing?
11 Replies 11
I checked this and it was working in AC19.
And indeed, it doesn't work in AC20.
I will report this to GRAPHISOFT.
In the meantime, you can activate the saved View, then go back to the Floor Plan, move the Camera, then right-click the Camera and Show All in 3D.
The 3D View is changed in its TAB. Right-click the TAB and click the Save View command. This way the View will be updated with the new Camera location.
vfrontiers
Just ran into this today..
Similarly, I just edited the camera, went to 3d window and right clicked the VIEW MAP entry setting... Use the big ole button that says UPDATE VIEW WITH CURRENT 3d WINDOW and it updates.
I like the TAB idea though... Never would have thought to go there.
Duane
Visual Frontiers
AC3.14 - AC29
:|: Enscape4.16:|:TwinMotion
vfrontiers
Loosely related...
I have forever uses the CAMERA PATH to start a MOVIE of the KEYFRAMES to allow me to render several views overnight...
I know used the PUBLISHER with the VIEWS of 3d renders as set up in the Navigator...
My issue is that I cannot tell the 3d window to RESET / REBUILD with all my POSTCARD PLANTS using this method...
Bugger...
I can envision my only work around to be including a BOGUS render in between each that turns of the plant layers... Then turns back on for the subsequent render in which the 3d will be forced to REBUILD with those layers.
Any input is welcome!
d.
Duane
Visual Frontiers
AC3.14 - AC29
Same problem here. In ver 20 you always need a couple of extra clicks. So troublesome.
Katalin Borszeki
Hi All, we have reproduced this issue and entered it to our defects database. It has a high priority and is planned to be corrected. As a workaround, we suggest to follow Laszlo Nagy's steps:
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
http://helpcenter.graphisoft.com - the ArchiCAD knowledge base
I am working in AC21 and this still doesn't seem to be fixed unless I am missing something. This is very inconvenient. I used to be able to set one camera (viewpoint) and show multiple types of views based on that one camera angle. For instance, from the same camera angle I could show the model in white model, color, different shadowing based on the time of year, with and without trees, etc by cloning the camera multiple times in the view map and then changing the view map settings. If I changed the camera, all of the view map views were updated. I can't figure out how to do this anymore and if this is even an option in the newer versions.
PVBergkrantz
Working in AC22 and this still does not work. It would be super useful to have the exact same view for multiple renovation layers, graphic overrides, layer combinations etc, and be able to change the angle for all of them at once. Anyone have a better method than updating them one by one?
| AC 29 Int | Win11 | i7-7800X | 32 GB | GeForce RTX 2060 6GB |
Jody S Keppers
Still not fixed in ArchiCAD 23. How can a problem like this still not be fixed? The workaround is a real nuisance.
Keppers Design Architecture
AC user since 1997 - currently AC 27
Mac Studio 2022, 64GB, 8TB SSD, Sonoma
MacBook Pro (15 inch 2019), 32GB, 1 TB SSD, Sonoma
iMac 27" retina display (late 2015), 16 GB, 2TB hybrid drive, Monterey
alex_kemp
Hi I'm running into this same problem in AC25 - has this been fixed??
