Visualization
Visualization Error in Archicad 23-25 with GRID NVIDIA drivers version 16
Ghissu
I’m experiencing an issue with visualization in Archicad versions 23-25. I encounter this error:
eventlog:
Spoiler
Faulting application name: Cineware.exe, version: 23.2.0.0,timestamp: 0x603e7e18
Faulting module name: KERNELBASE.dll, version: 10.0.22621.3447, timestamp: 0x3d876852
Exception code: 0xe0000001 Error offset: 0x00000000000653ac
Faulting process id: 0xF34
Application start time of the failing application: 0x1DAA60851F6B570
Path of the failing application: C:\Program Files\GRAPHISOFT\ARCHICAD 25\Cineware\Cineware.exe
Path of the failing module: C:\WINDOWS\System32\KERNELBASE.dll
archicad is not demo, codemeter is working.
Interestingly, when I install older driver version 13.9 (474.64) on the virtual machine, the visualization process works without any errors, and the Cineware.exe process does not crash or close unexpectedly.
Could anyone provide insights or solutions to address the error with the newer NVIDIA GRID driver version?
Thank you.
Operating system used: Windows 11 23H2
0 REPLIES 0
Setup info provided by author
