Where do I get more exterior surfaces?
I want my house to have a natural stone siding. I don’t see this or any types of stone in the software.
Thanks,
Scott
3 Replies 3
Update: I found various stone surfaces, but they are not what I need. Is there a resource with more options?
Thanks,
Scott
David Maudlin
Scott:
If you are referring to the texture, you can modify or create a Surface with any texture (bit map image), in the Help files see: User Interface Reference > Dialog Boxes > Surface Settings (CineRender) > Surface Texture Panel (Internal Engine). Searching the internet will yield many textures for use.
If you are referring to the Vectorial Hatching, again you can create a custom Fill, in the Help file see: Documentation > Fills > Create or Edit Symbol Fill.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks
