White Model
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-03-09
04:23 PM
‎2023-05-11
01:35 PM
Noemi Balogh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-19 02:49 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-20 03:36 AM
We have made up a surface attribute set for doing something very similar.
It's not ideal but it is a very quick solution once it is setup.
Plus it allowed our designers to still use trees with a transparency and grass where they liked.
First up export your standard surfaces through attribute manager, save as.
What we did then was replaced settings from catalog for each surface, except our glass and grass surfaces, with the wall finishes - paint 18 - titanium white.
Then adjusted our glass materials to be the blue reflective that our designers liked.
We then exported that surface set as another attribute file called white set.
Once you have those exported, you can over write the surfaces of each project in attribute manager for the renders and then once you are done,
simply overwrite the surfaces back to your standard set.
As I said, not ideal but it does allow for some cool effects.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-03-21 02:34 AM
I will give that a try.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-11-03 11:44 PM
