Visualization
Who wants an ArchiCAD -> 3ds max/VIZ step-by-step guide?
stefan
As some of you might know, I wrote a step-by-step tutorial to convert an ArchiCAD model into Cinema4D.
Is anyone dying to have the same thing for 3ds max/VIZ as well?
Or other suggestions?
Archicad-user since 1998
my Archicad Book
1 REPLY 1
stefan
Ok. 10 votes for 1000 members. Is that good or not?
I'll wait a bit, but I guess I'll start to think about it. Would it be fine it if was the same tutorial as for Cinema4D but then using VIZ/3ds max? I'll try to make it independent of the version, so it'll work in all versions.
The radiosity (as available in VIZ4/2005 & max 5/6) could be adjusted at the end.
I won't cover VIZ Render, since it needs the files to pass through AutoCAD first and is only sold with AutoCAD. There are not many people that have (and use) both applications.
my Archicad Book
