ā2015-05-15
02:07 AM
ā2023-05-11
01:56 PM
Noemi Balogh
ā2015-05-15 04:04 AM
Brad wrote:You're not the only one
Please see the enclosed images. When you look at a window through the door glass the window disappears. I am out of ideas.
ā2015-06-04
09:00 AM
ā2021-10-23
12:45 AM
I believe you need to change ray treshold and depth settings to fix your issue.
Go to PhotoRendering Settings, check Detailed Settings under CineRender and then navigate to Options - General Options.
Hope that helps
ā
ā2015-06-04 05:13 PM
Brad wrote:So when you move the camera out side the window re-appears, correct?
ā2015-06-08 01:53 PM
ā2015-06-08 05:47 PM
ā2015-07-22 11:12 AM
