Visualization
Wobbly reflections in Cinerender
We are having issues wiht reflections in Cinerender (ArchiCAD 21).
As you can see from the attachment, the reflections are coming out wobbly, instead of in straight lines as per the original subject.
We are using the standard material from the catalogue, 'Glass - Clear Fast' and using the 'Outdoor Daylight Final' scene with all standard settings except lights turned on to 130%.
No idea why the reflections are coming out wobbly though. Any ideas?
Thanks in advance for any help.
Erwin Edel
There is a bump channel on the standard glass surface, which is causing this. You can turn this off.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
Erwin Edel
www.leloup.nl
Windows 10 Pro
Awesome! Thanks Erwin. Love an easy fix!
Erwin Edel
Glad to help, took me a few hours to figure this out back with ArchiCAD18 and first rendering with cinerender
You might want to try to dial back the preset settings a bit, if you find that final render is taking a very long time.
www.leloup.nl
Windows 10 Pro
