Visualization
another lightworks rendering error
teamwork file in archicad 11
623,345 polycount
marqueed area, layer combination to show only exterior
no landscape
tried saving as a solo project
tried rendering on different computer
tried redirecting the temp and cache folders
lowered resolution and using only sun in settings (no extra lights)
deleted errored library part
rebooted computer
created custom library part from model
nothing worked
still can't get a render
manage to finish one this morning
but won't do a second
even after cleaning out temp folder
helphelphelphelp
pc
2gigs of ram
intel(R) Core(TM)2 CPU 6600@2.4GHz (2 CPUs)
Djordje
try it in 10 as described here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=98787#98787
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
fixed it... there was another rouge part that lightworks did not like...
a custom composite wall.... deleted it... now no problems rendering
i did read the other post... but wanted more than a temp solution
i wish when there is a problem rendering archicad would pin point the problematic part... it would've saved me a few hours... picking apart every piece of a 15 story model
all is better now
whew...
happy friday!
