Visualization
Render your model with built-in or 3rd-party solutions
billboard shadow casting
I am having trouble under archicad 9 when rendering billboard objects such as "tree bitmap" or "people bitmap". Specifically the object will not cast shadows, even though the object is set to cast shadows. All other genuine 3D objects cast shadows in the scene. This happens with the internal engine and the lightworks engine. What am I missing out?
Kind regards
7 REPLIES 7
Wouldn't you know it. I spend hours trying to resolve the issue. Then minutes after posting, I find that there is an update patch that fixes this exact issue.
http://www.graphisoft.com/support/archicad/downloads/ReleaseNotes1965.html
Kind regards
The transparent picture with bitmap-picture is just possible with internal engine (not with Lightworks engine).
Or?
At least your wish was quickly granted. 😉
I just confirmed that people, tree and car bitmap objects in the 9 library do cast proper shadows with LW before I read your newer message.
Karl
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Scott Bulmer
Karl Ottenstein wrote:
I just confirmed that people, tree and car bitmap objects in the 9 library do cast proper shadows with LW...
Karl (if you're out there),
I have build 2172 and am not able to have the Tree Bitmap objects cast a shadow when using Lightworks. The objects have the shadow parameter set to on as well as the object sun parameter to cast shadows. I must be forgetting something.
Any thoughts are deeply appreciated.
Thanks,
Scott
AC27 v. 4060 w/ MEP, Cadimage, Twinmotion 2023.2.2 using AC from AC6.0, 2021 MacPro M1 chip, Adobe CC. Used AC on both platforms.
Works fine for me, Scott. I even get soft shadows form the LightWorks sun object. Works fine for custom bitmap, too. (In fact, works better as my custom tree is higher resolution and better masking than the built-in images.)
If you have shadows 'on' for the tree, and 'by lamp settings' in the PhotoRendering Settings dialog for LW, and your sun is at an oblique angle to the tree builboard, then I can't imagine why you're not getting shadows...
Karl
Scott Bulmer
Somewhat awkward and embarrassing, I needed to update our SE9 Library to that PLA issued in 01-06. NOW, everything works just perfect. Sorry about that.
Scott
Scott Bulmer
Karl,
I couldn't privately send this to you, but thought you may get some level of entertainment out of it.
Thanks again,
Scott
