alemanda
cinerender - reflections
How to get reflections of the glasses in a fast rendering process?
I got the reflections only using the "outdoor final method" both normal and phisic render engine.
What's the parameter to enable to get the reflections?
eng. Alessandro Mandala - Italy
AC27 latest hotfix
Win 11 Pro 64bit
Ultra 9 275HX 64GB GeForce RTX 5070ti
2 Replies 2
Try increasing glass optimization level under Global Illumination> Details:....
And then increase the Reflection depth under Details>General Options:-
(also a good idea to increase Ray Depth while you're at it; anything between 15-20 should give you decent looking glass reflections)
Make sure you use a glass material with good reflection values and settings otherwise this will not work.
Ideally they work with the default glass you get in the Materials Catalog available with AC18
alemanda
Thank you very much!
AC27 latest hotfix
Win 11 Pro 64bit
