ā2009-10-12
01:16 PM
ā2023-05-26
03:09 PM
Rubia Torres
ā2009-10-12 03:17 PM
ā2009-10-12 06:04 PM
ā2009-10-12 06:52 PM
ā2009-10-15 04:02 PM
ā2009-10-15 04:03 PM
ā2009-10-15 08:32 PM
ā2009-10-15 08:38 PM
ā2009-10-16 12:01 AM
ā2009-10-16 04:16 AM
Nick wrote:If it is correct in plan then it should be correct in elevation as well.
Percy,
If your plan is showing correctly? then I suspect you have the same fills adjacent to each other in your composite wall. (your example looks like an empty fill) Archicad will automatically join these in sections. Just change fill types between adjacent skins. If you don't want a fill pattern then save an empty fill with another attribute.
HTH.
