Learn more
create fly-through (Help)
Hi
I am trying to create a fly through of a ArchiCad Group project and the error message is "No free disk space" and it is unable to render.
I am using ArchiCad 9 Student Version.
OS Windows XP SP2
Hardware is pretty new
Intel Core 2 Duo E6400 2.4 GHZ
Corsair VS Ram 2 GB DDR2 533 MHZ Ram
Free Space on C Drive 45 GB
Graphics Gigabyte GV-NX76T256D-RH 256MB DDR3 ram
(256MB GDDR3 memory and 128-bit memory interface )
PC does not have any memory issues etc. Runs fine and does not crash etc.
The project i am trying to render has 505 frames.
Please suggest what to do.
Any help is greatly appreciated.
I am able to create fly throughs for small projects.
7 Replies 7
Djordje
LightWorks rendering engine?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
TomWaltz
Is your disk actually full?
Tom Waltz
1. No the disk is not full. It is a 320GB HDD. The primary OS partition is 100GB. It has more than 45 Gb of free space.
2. I have tried with the lightworks rendering engine as well. Still comes up as "No free disk space" and it is unable to render.
3. I have 2GB DDR2 Ram. Even with ArchiCad running I have more than 1.3GB of free (physical) ram.
Are their any settings that i need to fine tune?
Thanks for your help.
hi,
My problem is solved.
the only thing that was required was to change the no of key frames.
Thanks
Hi
The error message is back and it says
Disk is full or not enough memory to create 3D data structure. (error code:22)
Free memory at the time of this error message was around 650MB.
ArchiCad 9 was using around 850MB Ram.
Please suggest what i need to do.
Error message is
Options are
Stop Continue
Projection : Custom axonometry
Camera azimuth : 37.4502
Start time : 1/13/2007 11:26:21 AM
End time : 1/13/2007 11:26:21 AM
Elapsed time : 0 seconds
Duplicated database name "AC_9_INT"
at line 1 of file MASTER_GDLAC_9_INT.gdl.
Duplicated database name "RoofMaker 2.1"
at line 1 of file MASTER_GDLRoofMaker 2.1.gdl.
Document name : Group2_Master.ppe
Processed : 237 walls 201 objects 76 columns 0 ncBeams
81 slabs 0 meshes 0 pitch roofs
Start time : 1/13/2007 11:26:56 AM
End time : 1/13/2007 11:26:58 AM
Elapsed time : 2 seconds
Camera azimuth : 33.0216
Start time : 1/13/2007 11:26:58 AM
Processed : 0 walls 0 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:28:00 AM
End time : 1/13/2007 11:28:00 AM
Internal Rendering Engine
Image size : 992 x 648 (2511 K)
PhotoRendering :
Start time : 1/13/2007 11:28:02 AM
Shadow body generation time : 0 seconds
Model info : 19116 K ( = 13128 K + 367 K shadow bodies + 5621 K projected)
: 88416 polygons, max. 5642 in one scan-line
End time : 1/13/2007 11:29:03 AM
Elapsed time : 1 minutes 1 seconds
Processed : 0 walls 14 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:30:19 AM
End time : 1/13/2007 11:30:19 AM
PhotoRendering :
Start time : 1/13/2007 11:30:20 AM
Model info : 2804 K ( = 1990 K + 61 K shadow bodies + 754 K projected)
: 11117 polygons, max. 992 in one scan-line
End time : 1/13/2007 11:30:55 AM
Elapsed time : 35 seconds
Processed : 2 walls 1435 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:33:09 AM
End time : 1/13/2007 11:33:13 AM
Elapsed time : 4 seconds
Start time : 1/13/2007 11:33:14 AM
End time : 1/13/2007 11:33:14 AM
Start time : 1/13/2007 11:34:03 AM
End time : 1/13/2007 11:34:04 AM
Elapsed time : 1 seconds
Disk is full or not enough memory to create 3D data structure. (error code: 22)
Start time : 1/13/2007 11:50:40 AM
*** User Break ***
End time : 1/13/2007 11:50:44 AM
Dwight
You will execute a Problem Isolation Exercise to locate the corrupted element that is causing the wacky 3D file.
This problem is most likely an irrational slab or a library part.
To loacte the bad element, turn off 1/2 of the layers and see if the problem persists. If not, then you know it is in the other 1/2 of the layers.
Show 1/2 of them. If not, etc... Through this process of elimination, you can find the layer where the bad part is.
Take this element out and beat it until it behaves.
Dwight Atkinson
Thanks Dwight i will try this and let you know.
