create fly-through (Help)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2007-01-11
01:03 PM
- last edited on
2023-05-11
12:28 PM
by
Noemi Balogh
I am trying to create a fly through of a ArchiCad Group project and the error message is "No free disk space" and it is unable to render.
I am using ArchiCad 9 Student Version.
OS Windows XP SP2
Hardware is pretty new
Intel Core 2 Duo E6400 2.4 GHZ
Corsair VS Ram 2 GB DDR2 533 MHZ Ram
Free Space on C Drive 45 GB
Graphics Gigabyte GV-NX76T256D-RH 256MB DDR3 ram
(256MB GDDR3 memory and 128-bit memory interface )
PC does not have any memory issues etc. Runs fine and does not crash etc.
The project i am trying to render has 505 frames.
Please suggest what to do.
Any help is greatly appreciated.
I am able to create fly throughs for small projects.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 08:43 PM
ArchiCAD since 4.55 ... 1995
HP Omen
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 08:46 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-11 10:00 PM
2. I have tried with the lightworks rendering engine as well. Still comes up as "No free disk space" and it is unable to render.
3. I have 2GB DDR2 Ram. Even with ArchiCad running I have more than 1.3GB of free (physical) ram.
Are their any settings that i need to fine tune?
Thanks for your help.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-12 07:19 AM
My problem is solved.
the only thing that was required was to change the no of key frames.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-13 09:51 AM
The error message is back and it says
Disk is full or not enough memory to create 3D data structure. (error code:22)
Free memory at the time of this error message was around 650MB.
ArchiCad 9 was using around 850MB Ram.
Please suggest what i need to do.
Error message is
Options are
Stop Continue
Projection : Custom axonometry
Camera azimuth : 37.4502
Start time : 1/13/2007 11:26:21 AM
End time : 1/13/2007 11:26:21 AM
Elapsed time : 0 seconds
Duplicated database name "AC_9_INT"
at line 1 of file MASTER_GDLAC_9_INT.gdl.
Duplicated database name "RoofMaker 2.1"
at line 1 of file MASTER_GDLRoofMaker 2.1.gdl.
Document name : Group2_Master.ppe
Processed : 237 walls 201 objects 76 columns 0 ncBeams
81 slabs 0 meshes 0 pitch roofs
Start time : 1/13/2007 11:26:56 AM
End time : 1/13/2007 11:26:58 AM
Elapsed time : 2 seconds
Camera azimuth : 33.0216
Start time : 1/13/2007 11:26:58 AM
Processed : 0 walls 0 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:28:00 AM
End time : 1/13/2007 11:28:00 AM
Internal Rendering Engine
Image size : 992 x 648 (2511 K)
PhotoRendering :
Start time : 1/13/2007 11:28:02 AM
Shadow body generation time : 0 seconds
Model info : 19116 K ( = 13128 K + 367 K shadow bodies + 5621 K projected)
: 88416 polygons, max. 5642 in one scan-line
End time : 1/13/2007 11:29:03 AM
Elapsed time : 1 minutes 1 seconds
Processed : 0 walls 14 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:30:19 AM
End time : 1/13/2007 11:30:19 AM
PhotoRendering :
Start time : 1/13/2007 11:30:20 AM
Model info : 2804 K ( = 1990 K + 61 K shadow bodies + 754 K projected)
: 11117 polygons, max. 992 in one scan-line
End time : 1/13/2007 11:30:55 AM
Elapsed time : 35 seconds
Processed : 2 walls 1435 objects 0 columns 0 ncBeams
Start time : 1/13/2007 11:33:09 AM
End time : 1/13/2007 11:33:13 AM
Elapsed time : 4 seconds
Start time : 1/13/2007 11:33:14 AM
End time : 1/13/2007 11:33:14 AM
Start time : 1/13/2007 11:34:03 AM
End time : 1/13/2007 11:34:04 AM
Elapsed time : 1 seconds
Disk is full or not enough memory to create 3D data structure. (error code: 22)
Start time : 1/13/2007 11:50:40 AM
*** User Break ***
End time : 1/13/2007 11:50:44 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-13 11:20 AM
This problem is most likely an irrational slab or a library part.
To loacte the bad element, turn off 1/2 of the layers and see if the problem persists. If not, then you know it is in the other 1/2 of the layers.
Show 1/2 of them. If not, etc... Through this process of elimination, you can find the layer where the bad part is.
Take this element out and beat it until it behaves.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-01-13 09:03 PM
