Visualization
good jpg or tiffs by publisher ?
simple but big problem.... want to publish my plans as a jpg or tiff. but the quality is horrible. how can i modify the quality?
thanks jens
11 REPLIES 11
Achille Pavlidis
i hope this is not completely off-topic... but i have noticed that when publishing to pdf i always get "true weight" output, even with "hair lines" is selected... why???
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
gerd
in plotmaker you get always the "true weight" output, "hair lines" is only for viewing (in archicad this is different)
if you need "hair lines" in your pdf duplicate the layout, mark the drawings and set all pens to 0.00mm. if you use brightr grey color, maybe something gets nearly invisible.
best regards, g
