how can i build a neon light
hi to everyone. i have a problem, i can't crete a light source that can simulate neon light tube. i tried to use window light but there is a problem it works in relation with the sun position so it wont work for interior light. so do you have any idea to create one?
thank you
12 Replies 12
David Maudlin
thank you
Syber:
Have you tried changing the "Set Sun Position" parameter from Off to On? This allows you to set the sun position for this light source and not use the project sun position.
Hope this helps.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Dwight
neon tubing is made with an "emiiting" material - Pipeline>Graphisoft Emission - set attenuation to simulate the ezposure - more attenuation will make a more round tube. But it is not a light source.
This window light can be aimed at any surface - you would place it in front of your tubing facing backwards to softly make a wall glow. Perhaps you need two of them - one neon color and one white-ish.
We don't have the special effect enabled to easily use the Lightworks neon defined materials.
Dwight Atkinson
Dwight
Neon Solved.
Write to me at:
dwight_atkinson [at] telus.net
replacing [at] with @
and I will send you the preview article from my book concerning this.
Dwight Atkinson
Nice effect, I also found it interesting to know that the animated gif files maintain their animation in the preview.
Mark
Dwight
Sure, but the garbage tracing your image means the file is too big. Not too big for the upload, but too big for the imaging engine.
Dwight Atkinson
I think it is too small, the preview is set to a specific ratio, and the gif is wandering. Maybe?
Dwight
some kind of compression/optimization issue. Can I call you?
Dwight Atkinson
Not necessary, I am sure that if I created a graphic with the exact dimensions as the preview, there would be no problem.
But you can call whenever you want, big fella.
There is special effect Iwa.
You can downloade it from Light works.
http://www.lightworks-user.com/downloads.php?type=category&filter=Essential
How good...I can not say.
Good luck
