how do I slow down my fly-thrus?
I am trying to make my first major rendered animation in ArchiCAD 9 (with LightWorks).
Everything looks great, but my movie is over way too fast and the camera-view looks almost like Clark Kent running through Smallville at super-speed.
How do I make a longer, and much slower Quicktime movie in ArchiCAD 9? Any help will be greatly appreciated, and there is no such thing as too many suggestions here, guys.
thanks!
Grenderer
14 Replies 14
Tips in this thread might help you... http://archicad-talk.graphisoft.com/viewtopic.php?t=7945
or do a search of the forum (button above) for more advice.
Cheers
Cheers
Thanks so much!!!
grenderer
Dwight
While I like to harp on my favorite gripe about ArchiCAD fly-throughs being impossible to smooothly accelerate and manoever, properly exploiting the best quality LightWorks images means using larger, high-quality images represented as a few cross-fading captioned slides rather than many smaller, poor quality images.
Try it:
faster rendering, clearer imagery and better communication in all respects.
Dwight Atkinson
You could be a politician Dwight, not answering the actual question. The difference in your case is that you actually make sense though!
Buttering up the bosses to get that book....
Dwight
At ACUE this year, the Artlantis guys went through a big rigamarole to make a fly-through with Artlantis R (a great software for pirates: "Artlantis… arrrrr!") that doesn't have multiple cameras right now.
I sat back and wondered why they bothered: there wasn't more actual information in the animation than five good renderings would provide and the path was stilted. Lot of work to try to be cinematic and still failing.
What is this obsession with bad movie-making?
Dwight Atkinson
rjwilden
Is there a cheap program that enables you to pan and zoom into and across a still image. I have seen this done to good effect and think it might be a better alternative to movie animations and a lot quicker to set up.
Richard.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
Dwight
There is a fine program I recommend called:
Still Life.
It allows the programmed transition of slides and all the panning/zooming a lad needs.
soundtrack, too.
Dwight Atkinson
rjwilden
Looks like this is a Mac product, any other for windows. Looked like it would do the job though.
Richard
Archicad V23:V24
Dwight
With some minor tricks, both PowerPoint and Keynote can easily do the same tricks as Still Life - except the rotating.
You just cross fade between different places on the same image.
Get creative with those multi-media tools. A slide show isn't JUST a slide show any more...
Dwight Atkinson
