koh-I-noor setting missing
Hello everyone,
I´ve been using the koh-i-noor setting for doing sketch renderings but since the update to archicad 18 (both student version international and austrian), this setting is no longer available!! Quite a problem, cause it´s the setting I´m used to… Anyone knows why is it missing or if it´s just a configuration problem? Is it generally missing or just on the student version? Thanks for your help!
2 Replies 2
Eduardo Rolon
Missing also from the defaults in the Pro version but if you select "Manage Scenes…" you should be able to find it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you ejrolon! Saved my day
