ā2006-11-03
05:26 PM
ā2023-05-11
03:08 PM
Noemi Balogh
ā2006-11-03 05:54 PM
ā2006-11-03 07:54 PM
Why are you using Indesign for layouts instead of doing it all in Archicad?
ā2006-11-03 08:03 PM
ā2006-11-03 08:44 PM
We've been using PDF, but EPS would be a lot better to still have.
ā2006-11-03 08:48 PM
aa_norway wrote:I've never given PDF a second thought. I only ever make PDFs from layouts, just to make sure the paper size is already set.
What is your experience using PDF's ?
to me, it is time-consuming as i constantly have to configurate to
a) make sure of the excact physical size of my individual drawing
b) restate the scale of my drawings (ArchiCAD seems to believe their users want "fit to page" plans, with scales like, say, 1:158,,,)
c) use a lot of clicks to publish! (as i don't like having the huge Organizer-window open)
ā2006-11-03 09:30 PM
I "Shortcut" my layouts into the Publisher in my Template, so any sheets I create are in my Publisher ready to make into PDFs whenever I hit "Publish
ā2006-11-03 09:34 PM
aa_norway wrote:Archicad PDFs are kind of one-size-fits-all. There really are no export settings. I use PDFs that it generates are either for printing or for putting into InDesign or Illustrator.
seems like a nice and quick way to produce .pdf's,,,
but should you choose to send a 10page pdf, one for print and one for web, how do you proceed? how optimized are the vectorial information and the bitmaps? and how do you choose your settings, create profiles etc.?
all this i believe InDesign handles well, but communication through way heavy .pdf's from ArchiCAD 10 is a pain. Using Plotmaker at least made it possible to generate good .eps.
and,,, Fills are a real pain! and,,,, i use'em alot,,
ā2006-11-03 10:14 PM
Why would I put PDFs on the web?and personnally, hitting 1 button to print it all suits me fine (especially as i have a bad habit with fills,,, it takes time,,,
ā2006-11-03 10:17 PM
aa_norway wrote:I'd make them an 8x11 drawing. I never let any drawing out of my hand without a title block and date on it. Even packed with fills, it should not be that big.
by the web, i kind of meant the screen,,
like as if you sent a lightweight .pdf scetch for a client to peek at, but not to actually print/use? (keep'em coming back to collect my dimes,,,)
Why would I put PDFs on the web?and personnally, hitting 1 button to print it all suits me fine (especially as i have a bad habit with fills,,, it takes time,,,)
