material acting as a light source
Hello!
How can I create a material acting as a light source?
Is it possible to do it?
Thank you!
1 Solution
Carstenem
Yes you can to a certain extend. For the material settings see the screen capture ( play with the Generate GI Strength ) and an example like the lights I did under the garden steps.
Cheers Carsten
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Go to post
5 Replies 5
Carstenem
Cheers Carsten
Carsten
www.asmtechbase.com
Thank you Carsten!
Actually it was right that tutorial of yours that I was confused with, regarding the part with the light material
So I guess I have to orientate the model towards the West, so the sun can reflect in this material?
Carstenem
If you want to reflect the sun on a material, yes it has to be "in view" of the reflection. This has nothing to do with material acting as a light source though.
Carsten
www.asmtechbase.com
Erwin Edel
The Glow parameter on surfaces is just a postproduction effect applied to your render. It does not cast light.
It also increases render time dramatically, so you might have faster result applying a similar effect in something like Photoshop.
There are lightsources that you can give a shape, though. Maybe these can be used to achieve what you're after.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Thank you all for your replies!
