Wall surface/treatment shown in plan
jattt
Hello,
I am looking for a BIM parameter that could allow us to display a wall surface material in plan defined by a colour like this:
Right now the practice in our office is to manually draw 2D lines to display surface treatments, but this takes time and is a source of human error. Is there any way you could make this process more intelligent by defining a parameter within the wall and using a graphic override to display in plan? Maybe similar to how you can show the operating area of a door;
(English isnt my first language, by operating area I mean the requirement of free space from the door handle to the next obstacle)
I'm aware that the composite would display the material, but these plans are for treatment/finish, i.e. same composite painted in a different color etc.
Thanks in advance. 🙂
3 REPLIES 3
If walls were objects (like the doors) it would be relatively simple with a bit of GDL scripting.
You were on the right track with Graphic Overrides.
You can override the pen colour, line style, fill type of a wall based on certain criteria (like wall surface material).
But unfortunately this will not work either, as a Graphic Override will affect the entire wall.
So if you have different surfaces on each side of the wall, it will only show one override.
Also it doesn't add a coloured dashed line to the side of the wall it changes the actual wall.
So unfortunately, as far as I know you are stuck with manually drawing a coloured dashed line as you are now.
You could maybe achieve this with an add-on, but you will have to be an add-on developer to do this.
Actually you could possible utilise the existing wall accessory add-on (saves you having to create one).
But you will then need to know GDL scripting to be able to create a wall accessory object - that might be possible.
Not something you could do yourself though without learning at least some GDL.
Alright, thank you for a thorough reply! 🙂
I don't know GDL scripting, so I'll hope for this to be implemented at some point in the distant future.
fabioverissimos
Hello!
Any development on this?
In Portugal this is a very common way to display the diferent wall finishes.
Fábio
Versions 12 to 27
AMD Ryzen 2600, 16GB RAM, RX580 8GB
Windows 11 & OS X Monterey
Intel Core i7-13700KF, 64GB RAM, Nvidia RTX 4070 SUPER 12GB
Windows 11
