moving cars in movies???
is thier any way to make a car or an airplan movies in a movie ,as i see sometimes in 3Ds movies,and cad we make the lights less or more with the progress of the movie as in sunset or sunrise?????
any help will be apritiated:)
hana a. farhadi
3 Replies 3
TomWaltz
Technically yes, you can. But it's not easy. Archicad really is not made to do that.
You can if you do a little GDL programming with the object and use the "Rebuild Model for each frame" option when rendering.
In GDL, you can get the current frame number, then use ADDx, ADDy, and ADDz (or the ROT commands) to offset the object a given distance based on the frame number.
Tom Waltz
You can get objects that move. I downloaded a couple of cars (can't remember where from, might have been Objects Online freebies) which had two objects, one for still shots, one for animations. (Porsche and Ferrari, don't know how suitable they would be for anywhere except Hollywood)
Djordje
Very suitable around here ...
Porsche also had working headlights.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
