new textures loading problem
I have large library of different textures (jpeg) and I want to use it in ArchiCad 9, but I do not know how. Please,somebody, help me.
2 Replies 2
hi, you have to load it using the "library manager", and then you can create several materials by choosing any jpg of your choice....
Also you can load a singular Jpg or tiff or png, etc... in the material window... by changing the texture and choosing one from "search.../load other object/ from file dialog box.. option".
It works a bit different if you're using the Internal Engine or Lightworks engine....
tell me if it works... i guess it can help.
Nando Mogollon
Director @ BuilDigital
nando@buildigital.com.au
Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
Thanks, Nando! It works and quite easy. No problems both with Internal and Lightworks engines. Thanks again.
