Visualization
rotated surface
David Bearss
I have a surface that displays correctly in the surface settings but is rotated in the model. If I rotate in surface settings the surface does not rotate in the model.Am I missing something probably simple?
David Bearss
Archicad 28/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
David Bearss
Whups, captured the Cinerender settings. Am actually trying to get to display properly in OpenGL.
David Bearss
Alienware 17 R5
Strange, I have just tried it with another Surface texture ( INT version does not have that Surface in its default template) and the texture rotation worked just fine in 3D OpenGL display.
David Bearss
Fiddled around and tried rotating 180 and that worked.
David Bearss
Alienware 17 R5
