2016-02-0101:29 AM - last edited on 2023-05-1112:49 PM by Noemi Balogh
I have a surface that displays correctly in the surface settings but is rotated in the model. If I rotate in surface settings the surface does not rotate in the model.Am I missing something probably simple?
Strange, I have just tried it with another Surface texture ( INT version does not have that Surface in its default template) and the texture rotation worked just fine in 3D OpenGL display.
Loving Archicad since 1995 - Find Archicad Tips at x.com/laszlonagy AMD Ryzen9 5900X CPU, 64 GB RAM 3600 MHz, Nvidia GTX 1060 6GB, 500 GB NVMe SSD 2x28" (2560x1440), Windows 10 PRO ENG, Ac20-Ac27
